new update....
Discussion in 'Civic and CRX - EF' started by podagee, Feb 4, 2010.
  1. podagee
    podagee New Member
    wailuku,hi
    okay ive been swapping stuff in and out of my car,dpfi-mpfi-dpfi and back to mpfi.so i finally swapped out everything correctly,but,new problem,the biggest so far,my car was trailing smoke heavily.i took it to my friend(at the rate of 20-30mph)and he was laughing cause he knew the problem.he said that a piston ring cracked.so that explains the loss of power,oil,and gas.
    now i need to swap the block.im thinking,d16a6 block with d15b7 head or d15b7 block with d16a6 head or just do a whole b7 swap.those are the only parts i have available.someone let me know what you think would be a decent swap.
  2. 90_EF_Hatch
    90_EF_Hatch Señor Member
    Dallas Texas
    The d16a6 block with the B7 head is called a "Mini Me" and is essentially the LS/Vtec of the D-series motors. Do some searching around the forum for "mini me" and im sure you will find tons of information on how to properly assemble it and what not. I know because i have looked into it before.
  3. Bobby17772
    Bobby17772 New Member
    Enfield, CT
    well...yes and no, it's kind of a mini me seeing you're using a different then stock head swap, but it's not a mini me because it's not a vtec head. so it's more or less a half assed or a lazy man mini me.
  4. 90_EF_Hatch
    Dallas Texas
    ahh ok. thanks for the correction, I was thinking d15b7's were vtec. what is the VTEC d15?
  5. Bobby17772
    Enfield, CT
    you may be thinking of the jdm d15b
    1 person likes this.
  6. DeathInACRX
    DeathInACRX New Member
  7. 90_EF_Hatch
    Dallas Texas
    yes sir.
