Nissan Maxima no spark
Discussion in 'Other Vehicle Discussions' started by 99sidude, May 28, 2009.
  1. 99sidude
    Ohio
    So my DD decided to take a shit on me this week. I drove it all last weekend traveling and it ran perfect. On tues I went to fire it up for work and it just crank and cranked with no firing. I checked and it's getting fuel into the engine, there isn't any spark at any cylinder. The car has a coil on plug ignition, and there's no way that all of the coil packs could go bad at once. I'm not getting any CEL's either and there are no blown fuses.
    I tried getting some help from Maxima.org and couldn't find anything in a search. They make you get 15 posts in some bs beginners forum before you can actually post. Any ideas on this?
  2. jeffie7
    jeffie7 Wrong Whole! VIP
    Maryland
    Try posting it on my350z.com is it a V6 or I4?
    anywho, check all your fuses, that's where I'd start.
  3. 99sidude
    Ohio
    It's a vq30 v6. I did check all the fuses. Might as well double check
  4. jeffie7
    Maryland
    check out my350z.com or a 300zx forum, do a search on your issue to see if other cars had that problem and what the cause/fix was.
  5. 95b16coupe
    95b16coupe New Member
    ct
    have you tried to jump it or anything?
  6. 99sidude
    Ohio
    I don't need to jump it. The battery is fine. The car cranks and the cylinders are getting fuel. Just no spark.
  7. jeffie7
    Maryland
    I think he's not asking if you tried to jump start it to get it running but rather have you tried jumping it before this was an issue. Maybe that was the cause but I'd think you would know that if that was the case.
  8. jeffie7
    Maryland
    From a random google search, not for Nissan but random cars.
  9. 99sidude
    Ohio
    Thanks for the help guys. After screwing with it more and letting it crank for awhile, I finally got a CEL to show up for the cam position sensor. I ordered the part at autozone ($60), and it will be in tomorrow afternoon.
