ok so im putting an h22a into a 92 eg and the clutch was fine before i took the old motor out. when i put the H in i ran the eg clutch line to the h slave cylinder and bled the lines. i ended up using a whole bottle of fluid and doing it correctly still no pressure whatsoever. I dont think it could be the master cyl because it was working before i did the swap.... lmk if u have any suggestions
