No Clutch Pressure
Dachdu 92
Hey everyone, I'm Thinking about buying a 3rd gen Prelude SI that was parked because it was sideswiped, and i went to fire it up and the clutch had no pressure, what does this mean? I doubt the clutch is broke because it is obvious it was parked because of the wreck (door doesnt close all the way). Does anyone know how to fix this?
probably the salve cyl on the tranny. they go, are fairly cheap and easy to replace. check the clutch fluid though, you may just need to top it off in the clutch master and pump it up a few times
is it cable or hydro tranny???if it is a cable tranny it is possible the cable snapped which is an easy fix also...
Should be a cable tranny for that year. Check the cable and see if it broke or came disconnected at tranny or clutch pedal.
could be the slave cylinder as B said, or the master cylinder
