No Fuel No Spark
Discussion in 'ECU's, Electronics, and Tuning' started by Itsmejoeyd, Sep 30, 2011.
  1. Itsmejoeyd
    Itsmejoeyd New Member
    So a while ago i replaced the radiator and t-stat in my civic. i started the car up letting the fluids run through and my car died. i tried starting it and since than it wont start. i replaced the dizzy and that didnt help at all. does anybody know what i can do to get it to start , it tuns over by the way. its a D16Y8
  2. Dual-500
    Dual-500 Well-Known Member VIP
    Fort Worth, Texas
    CEL codes. Any codes from the ECU?
  3. josh_crewdson@y
    josh_crewdson@y New Member
    nova
    make sure your t-stat ground is connected.
  4. luky1380
    luky1380 New Member
  5. Itsmejoeyd
    i cant seem to find the ground by t stat
  6. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    Bingo!
    Its attached to the wire harness. Just look around and it should come up.
  7. Dual-500
    Fort Worth, Texas
    Look at the thermostat on the engine - it's behind and below the distributor. The lower radiator connects there. There is a ground cluster there for the ECU and engine sensors.
    Gotta be connected.
