Noob needs help
buggaboo99355
what would i have to buy to swap a h22 dohc head on to a f22a1 block. would i have vtec and what kind of wireing would i have to do? and aprox how much would it cost? please help the noob i am sacrificing rep points by asking these stoopid questions.
Don't bother....it'll cost you more for machining than an H22 swap would run you
yea. i read here that a f22 block is stronger than a h22 block and that the only things on a h22 head that doesnt fit/line up is is one of the oil drain things and can be plugged up but the rest of them line up perfectly.
http://www.honda-tech.com/zerothread?id=1412600
i also believe that f-series are highly UNDERated even though i know that the head isnt that great, the block is ALOT stronger than a h22. my friend is running a stock f22 with 13psi boost.
