o2 censor
Discussion in 'Civic and del Sol - EG and EK' started by JDMB20Coupe, Aug 7, 2008.
  1. JDMB20Coupe
    JDMB20Coupe Powerd With 1 Cam
    Chester, VA
    ive got a D15B in my 95 civic and i just got a header from a Y8 motor so it doesnt have the o2 censor whole is i run it without the o2 censor will it mess anything up?
  2. t3t4delsol
    t3t4delsol New Member
    York, Pa
    you have to have it in, and what header doesnt have a o2 bung?
  3. JDMB20Coupe
    Chester, VA
    the bung is in the down pipe but i only have a down pipe for my motor
  4. t3t4delsol
    York, Pa
    im not really sure what your getting at. so where is the problem?
  5. JDMB20Coupe
    Chester, VA
    can i run the car with out an o2 censor until i can put the bung for it?
  6. t3t4delsol
    York, Pa
    no you will throw a cel and run really rich, just wait until you get the rest of it.
  7. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    So put it on the down pipe...
  8. caboose
    caboose USDM to the bone
    Hamilton, MI
    I typically only see censors late at night on girls gone wild commercials...
    If you are thinking about running without an o2 sensor, then you could, but I wouldn't advise it. It would run really rich and you would get piss for gas mileage.
    And if you have the dp for your motor, then why not just install that too?
  9. JDMB20Coupe
    Chester, VA
    i am but neither pne has O2 bung
  10. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    ive never in my life saw a honda header that didnt have a bung in it somewhere, but if not just go to the muffler shop and have them put one in there for you
  11. awptickes
    MD
    If you put the header on now, you'll have to take it off to weld the bung and put it back on again after they weld the bung.
  12. JDMB20Coupe
    Chester, VA
    oh ok thankyou its supposed to have it but its a Y8 header and z6 down pipe. and with those pieces the bung is on the other peice
  13. AHHVTEC
    Alabama
    even a y8 header should have it, it would have one on the header and one on the down pipe
  14. JDMB20Coupe
    Chester, VA
    idk but it doesnt have one so i have to make one
  15. t3t4delsol
    York, Pa
    honestly man I would pick up a cheap eBay header, they look a hell of alot nicer and are more efficient
  16. BrutalB83
    Rochester Hills, MI
    :werd:
    A stainless steel Megan Racing header is less then $150 shipped to your door. That's the route I would go...
  17. caboose
    Hamilton, MI
    My Megan bolts right up to my CRX and the Cat back. Really nice fit if you ask me. Unfortunately it has a little kink in it from the wrecked car I pulled it off of. Can't seem to get it out.
    o2 bungs are like $5 bucks though + getting it welded
  18. JDMB20Coupe
    Chester, VA
    its all good though cause im gettin a megan racin test pipe with the o2 bung so im just gonna use that
