obd confussion and identifying.....
Discussion in 'ECU's, Electronics, and Tuning' started by mojackson2390, Aug 18, 2008.
  1. mojackson2390
    mojackson2390 New Member
    how can i tell these things?...
    1) weather or not my ecu is obd1 or obd2?
    2) weather or not my engine harness is obd1 or obd2?
    3) weather or not my engine (b16a) is obd1 or obd2? (i dont know what car it came out of.....
    last thing...someone told me i need to make some hybrid harness for my engine because it has an obd2 ecu (not sure if they know their stuff) and the engine harness is from obd1....my car has a wire cut so that the fan is always on or else it wont turn on...know anything about this?
  2. efhondakid
    Akron-Canton, Ohio
    What year is your car? Is there a number that follows the "A" Such as B16A2, B16A3? Or just B16A.
  3. mojackson2390
    there is no number following the "A" my shell is a 96 i am not sure about the engine though..i do know that it was swapped.
  4. jlicrx
    jlicrx Senior Member
    Colorado Springs
  5. jlicrx
    Colorado Springs
    B16A is usually OBD0 from factory - what ECU do you have? - it will have a sticker on the case that says 37820-P??-???? - what distributor do you have? - on one of the attaching arms it will have a number like TD44U - chances are good that your car still has the original engine harness
  6. mojackson2390
    alright so i guess i have an obd-2b ecu and my distributor read TD-81i i think and then another set of numbers reading 0128...if my harness only has 2 plugs to plug into the middle of the ecu what harness might i have?
  7. efhondakid
    Akron-Canton, Ohio
    There are castings on the head above the exhaust that look like little clocks, they will tell you the year, (and month and day to I believe) the motor was made.
  8. mojackson2390
    it read 00 1 20 05 .....im am guessing made in 2000 so it is a bl6a 00 gen.? or 1 gen.?
