obd0 to obd1 swap
Discussion in 'HYBRID -> ED-EF / DA' started by electric_rex, Feb 10, 2004.
  1. electric_rex
    electric_rex Junior Member
    i have an odb0 to obd1 conversion harness, and i changed to a 4 wire o2 sensor but i was wondering if i had to use obd1 injectors because the conversion harness instructions mention nothing of it and if i did have to use the new injectors(which im not sure i do) how do i get rid of the injector resistor box(which i hope i dont have to)?
  2. D See 2
    D See 2 Senior Member
    Baltimore, MD
    you don't have to. leave the box wired as it is.
  3. Honeypooh
    Honeypooh New Member
    Does obd1 has any advantage over a obd0? I have a B16A DOHC Vtech, from japan vetech chips in at 4900 RPM running on a OBd0 Am i Loosing any power, if i converted to abd 1, would my car have more power, I am new to honda swap, can Pm please dont understand how to check response in open fo
  4. kevins39564
    kevins39564 Eric Cartman 4 President!
    Mississippi Gulf Coast
    Uhhhhhh, no.... In my opinion its the best version to go with as far ar tunability and compatibility, lotta options for an obd1 setup.. alotta people actually downgrade to obd1 from obd2.. If you get it chipped, a good engine managment system like Hondata, motec, F.A.S.T., Neptune.. something along those lines.. then you'll be on the right track.. but none of thats gonna do you much of any good unless you build you a motor to tune in the 1st place...
  5. efhondakid
    Akron-Canton, Ohio
    This thread is four years old.
  6. efhondakid
    Akron-Canton, Ohio
    Vetech, what the hell is that!
  7. kevins39564
  8. HATCHET_HONDA
    HATCHET_HONDA scottie fizzle
    hobart, indiana
  9. ep3moschini
    ep3moschini I R T3H NO00Bz!
    Northbridge Ma
    I wired in obd1 injectors when I did my swap. . . :ph34r: yopu dont have to tho
