OBD1 ALTERNATOR TO OBD2 WIRING
DEADLYACURACCY
Need to find out how to wire obd1 alternator to obd2 harness. My friend is dumb and wont buy/cant afford obd2 alternator and i have obd1 that i will give him to get his car out of my shop.!!! Help me!!!
i have a obd alt cap with wires u can splice obd2 wires should b 4 and hook my cap on it sodder it n ur ready to go
I am going to assume this is an obd1 b or d series swap to obd2 ek civic. Because this is the only time anything would be an issue. If this is what i think it is what you must do is use your obd2 d series alternator and make an adapter bracket so you can bolt it on. All i used was a couple extra nuts and a long bolt. Running a d16y8 alternator on my b16a 1990 motor in my 97 ex with no problems.
