jonnyboy0150
I bought an OBD1 b16 that came out of a Del Sol. The dude i bought it from says the only thing i will need to make the conversion is an oil pump from a newer model that has a connection for a crank position sensor. Is there anything else i will need other than an ecu? will my axles work?? will the header fit onto my current exhaust? Or will it be too expensive and too much trouble to complete the swap? PLEASE HELP!!!
