OBD1 B16 into an EK
Discussion in 'HYBRID -> EG-EK / DC' started by reckedracing, Feb 22, 2008.
  1. reckedracing
    reckedracing TTIWWOP VIP
    NY
    I'm looking to make the following work.
    Budget project. Don't tell me get an ODB2 motor cause the money isn't there.
    Looking to run OBD1 B16 on an OBD2 ECU/harness.
    Can it be done?
    Specifically wondering how to handle the crank sensor issue.
    Does the OBD1 B16 have any comparable wires to the crank sensor?
  2. eg6sir
    1 person likes this.
  3. reckedracing
    NY
    wow, you're the man
    next question
    will a OBD2a DX ECU run a B16
    performance isn't an issue here, we just need this thing to pass the OBD2 Ecu check to pass inspection.
  4. Matts96HB
    Matts96HB . Moderator VIP
    I'm sure it will run, but I'm almost positive you're going to have check engine lights.
  5. scottp11
    scottp11 The Seniorest Member....
    El Paso, TX now, originally from Fresno, CA
  6. eg6sir
