OBD1 distributor on OBD0 DPFI harness
PiXeL
Hi all,
I doing some weird swap.
I have an EDM Civic Dxi with OBD0 DPFI engine (D15B2)
I want to swap to D16Z6 but currently I will run this motor as DPFI non VTEC on the original harness (OBD0). (D16Z6 will be installed with the D15B2 intakes)
The problem is the the D15B2 dizzy doesn't fit the D16Z6 engine.
Is it possible to make the D16Z6 dizzy to work with the OBD0 DPFI harness?
This solution will be temporary until I'll get conversion harness and run the motor with p28 ecu
Not without running the PM6 ECU. If you're going to run the engine as a DPFI, you need to run the DPFI distributor. The ECU and distributor must match.
