obd1 gsr engine and harness -> obd2 Integra GSR-> obd1 Hondata ecu
Discussion in 'Integra' started by alterxerxes, May 21, 2007.
  1. alterxerxes
    alterxerxes New Member
    Having some problems with this swap. All of the connectors on the passenger side compartment fit except one.
    One connector is 3 wire (from the car) and the other is 2 wire (from the engine). Does anyone know how to modify this?
    Does this have to do with the iacv fix in the swap section (that I can't seem to start a new thread in)?
    If so, wouldn't the ecu conversion need to be taken into consideration in swapping the pins?
    [​IMG][​IMG][​IMG][​IMG]
