Obd1 Motor Into Obd2 Car
Discussion in 'HYBRID -> BA-BB /CA-CD' started by apok929, Apr 8, 2003.
  1. apok929
    apok929 Junior Member
    Ok...here goes. I installed a 95 h22a into my 96 accord. I also went ahead and converted from auto to manual. The motor starts up and purrs with no problems. When I rev it up..it redlines/bogs at 5400-5500. Has anyone experienced this before?...I am throwing a map sensor code which I will correct tonight. Hopefully this will resolve the issue. Just want to get answers just incase the map code isnt the issue. its the only code im throwing and a secondary O2 due to no piping installed right now. Thanks for your help.
  2. BlackJDMdeath
    BlackJDMdeath Senior Member
    Wichita, KS
    sounds like one of the codes you are throwing is a hard code, it will throw your ecu into a lower redline so you dont fux0r your engine
  3. Pootie
    Pootie Junior Member
    not so true
  4. Pootie
    what distributor and ecu r u running apok?
