obd1block in obd 2 car
Discussion in 'HYBRID -> EG-EK / DC' started by therod95civic, Jul 12, 2010.
  1. therod95civic
    therod95civic New Member
    ok i am doing this for a frend he has a 99 civic d series and spun a bearing i have a z6 obd1 block i am going to give him to get him back rolling what will i have to do as far as knock sensor and anthing eles i am keeping everything eles and just doing a block swap ant help thanks
  2. newb
    newb phresh VIP
    Backwoods Northwest
    I believe you just hafta drill and tap the block for the knock sensor. Im not positive though.
    <---In for the definit answer.
  3. D16SiHatch
    D16SiHatch New Member
    yep you need to attach that knock sensor one way or another.
    another problem is the z6 does not have a crankshaft fluctuation sensor (ckf). luckily it's not too difficult to bypass .:FFS TechNet:. ECU & WIRING How-To Articles CKF Bypass Trick
    aside from that just retain the y8 intake manifold and you should be golden lol.
  4. therod95civic
    cool deal i will try this and see ho t goes o what if i just get a obd1 p28 and a obd2a to obd1 harrneswill this soleve all the problems ?
  5. D16SiHatch
    its obd2b to obd1 but yes it will. it's exactly what i did when i installed a z6 in my 96. decided it just wasnt worth the hassle of staying obd2 when i also knew i'd need tuning capabilities in the future.
  6. d-mon
    d-mon what r u compensating 4?
    much better solution
  7. jdmkain
    jdmkain New Member
    We did the same to my boys ek with no problem u just gotta wire up the knock sensor
  8. dateg513
    dateg513 New Member
    cincinnati
    just put it in convert car to obdo1with no prob
