odd speed sensor problem
Discussion in 'General Tech and Maintenance' started by 2.2litrebeater, Jun 23, 2007.
  1. 2.2litrebeater
    2.2litrebeater Junior Member
    California, land of the governator
    we have a 90 accord with a 94 h22 swap, was running well for 2 years +. all of a sudden the speedo starts working intermidantly (sp?) it got worse as time progressed and now reads only for a second at a time very rarely. the trans died so we but a new one in and the problem is still there. here is where it stops making sense. with the speed sensor out put still plugged in you can spin the gear and the speedo will read like it should. however with it in the trans it has the problem rarely working. it is getting spun by the diff and if you take the very top off where the electrical plugs in you can see it spining so i know the gear is good. the trans oil is fine. any guesses?
  2. invisibledemon
    Tn
    wire shorting out?
  3. 2.2litrebeater
    i tested for a short with my multimeter, everything seams to be ok. but even if a wire was shorting out why did everything work fine with the speed sensor being turned while out of the trans?
  4. invisibledemon
    Tn
    well if everything spins in the tranny and the wires test good, then your speedo is probly just burnt out. most likely a short within the gauge cluster itself.
  5. boostedf22
    boostedf22 dis is why im not
    in the land of OZ
    Look for corosion on the plug it self. I had your problem. If you got the green gunk I had. Clean it with some contact cleaner w/ a small wire brush and see if that helped.
  6. 2.2litrebeater
    well there wasnt any corrotion but i think the pins were messed up, soldered on a new junkyard harness and it works great^_^
