Oil leak after tune
Discussion in 'General Tech and Maintenance' started by mozzandherb, Apr 25, 2006.
  1. mozzandherb
    mozzandherb Senior Member
    Had my h22 92 Accord tuned the other day and it's running really good, but there's an oil leak. It seems to be leaking from the bottom of the block on the drivers side and it's leaking quite a bit. Any ideas as what it could be? Head gasket? Thanks
  2. MikeBergy
    MikeBergy Blah blah blah....
    Central Coast, CALI
    where exactly is the leak coming from? Front, near header, or back behind the intake manifold. There are a TON of places oil could be coming from.
  3. VTECin5th
    VTECin5th Administrator
    Phoenix Az
    Did you change the oil filter during the tune?
    Check the oil pan bolts for looseness
    Check the oil pan gasket too
  4. mozzandherb
    The valve cover was taken off, but the leak is in the front at the bottom of the block on the drivers side. It's right above the oil pan.
  5. MikeBergy
    Central Coast, CALI
    You sure it's not the pan gasket?
