Oil leak need help please
Discussion in 'General Tech and Maintenance' started by operator1391, Nov 26, 2008.
  1. operator1391
    operator1391 New Member
    I got a 96 civic ex with 160.000 miles on it, I started to notice a small leak righ bellow the distributor , but now its leaking bretty bad. I dont know if its a head gasket, or the distributor "O" ring.I mean i got oil spotts every where i stop. I would appriciate anybodys advice
  2. t3t4delsol
    t3t4delsol New Member
    York, Pa
    lol so you leaking on the dizzy side, I just posted in you other thread. Where is the leak comming from? between the valve cover and the head? or between the head and the block? The dizzy does have a o ring on it, and you also have your vtec solinoid over there too. If your not sure where its leaking take a pic off the area and post it.
  3. operator1391
    well i dont know realy know were its comeing from, I just hope is not the head gasket.there seams to be a small puddle of oil right below the dizzy and allover 2 wire plugs under the dizzy, but its kida waterfalling all over everything
