hondanewbbb
H22a motor, the thing leaks oil like a pig, only when not under pressure? Ripped it apart today, vc gasket, cam seals, all look fine, it leaks right out of the head gasket. However, the cam seals were recently replaced and it could just be leaking behind them (behind the back timing cover). Which do you guys think is more likely? Cam seals or head gasket?
I would normally think head gasket (seeing that its coming RIGHT OUT of that area) but it only leaks when not under pressure, leading me to believe its not.
However: Cam seals dont seem like they would really leak all that much not under pressure either...
What do you guys think?
