oil pump removal d16y8 to d16z6
Discussion in 'HYBRID -> EG-EK / DC' started by poloboy4, Jul 29, 2009.
  1. poloboy4
    poloboy4 New Member
    washington
    dose anybody know the process? i been working on this motor keeping it obd2 now i think i just need the swap the oil pump to make the motor turn on this way i can add the crank sensor.
  2. d-mon
    d-mon what r u compensating 4?
    putting z6 oil pump on a y8 block?
    then where will you put the dipstick?
  3. poloboy4
    poloboy4 New Member
    washington
    Can't I keep it in the old spot and block off the new one?? I mean putting y8 oil pump on a z6
  4. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    Drain oil, take off the oil pan, unbolt oil pickup, remove crank pulley, remove timing belt cover, loosen tensioner and take off the timing belt, unbolt the oil pump.
  5. d-mon
    pretty sure you can.
    why not just use a z6/a6 oil pump?
    here is a link for a knock sensor bypass:
    http://www.honda-tech.com/showthread.php?t=1181854
  6. K2e2vin
    Raleigh, NC
    It's not knock sensor; it's CKP.
  7. poloboy4
    poloboy4 New Member
    washington
    Seems like alot of work half way there but I'm not sure if It will work :( well I'm gonna do it on my next days off will I need a new oil pan gasket?
  8. K2e2vin
    Raleigh, NC
    It's pretty simple as the only thing hard to get off is the crank pulley. Rest is 10mm bolts.
    It's recommended to change any gaskets since you're already in there.
  9. d-mon
  10. poloboy4
    poloboy4 New Member
    washington
    ok thanks for the info d-mon that site looks good thanks! and well yeah gona see if i can do it this Sunday or Monday.
  11. 97hatch
    97hatch ?
    Anderson IN
    there is a ckf bypass that you can bo by runing a few wires to the dizzy do a search you should find it on google
