I am putting the 97 b18b1 into my 94 civic. Can I use the intake manifold for the 97 or do I have to get one from a obd1 b18? I am using thw 97 integra wire harness. What would I do with the vacume line that went to the little sensor that went to the obd 1 manifold.
But you should use your civic harness with the obd2 manifold. Just "make it work". I'm using an obd0 manifold in my 93 hatch and using my civic harness.
Originally posted by 92civicb18b1@Apr 4 2005, 11:50 AM so your going to convert your car to obd2?
Maybe I'm just not all there today.
No I am using obd1 But the engine was from a obd2. There is a little map sensor that goes to the canister from my D series engine. Should I use that sensor? Or should I use the one that is mounted to the top of the manifold?
Originally posted by 92civicb18b1@Apr 4 2005, 05:50 PM so your going to convert your car to obd2?
OBD II Integra engine harness plugs right into 92-95 Civics at the shock tower. This allows you to use all the OBD II parts, without switching, and still running an OBD I ECU, sweet huh?
