P72 AND P28 SWAP pro & con
Discussion in 'ECU's, Electronics, and Tuning' started by fabtoys, Apr 3, 2008.
  1. fabtoys
    fabtoys New Member
    I got a d16z16 with a p28 in my 24 hours of lemons racecar and heard of performance going to the p72
    But want to make sure it has a rev limiter still does it and what rpm
    chipped p28 as good as p72???
  2. BrutalB83
    Rochester Hills, MI
    The P28 is the stock ECU for that motor, and it's very easy to chip and tune. Why would you want to run an ECU that's for a completely different engine?
  3. OKCZombie
    OKCZombie Banned
    because people assume that because an ecu is from a "higher performing" motor it will make their shit faster or better. They don't understand to use the right ecu or an ecu chipped to their setup. Also seems they don't know when it is time to consider chip and tune. It is quite sad really.
  4. BrutalB83
    Rochester Hills, MI
    :werd:
    I think I tell people that about an average of five times per day on here. Every noob seems to think that Honda ECUs are magical...
