parts needed for tuning a pre-chipped ECU
Discussion in 'ECU's, Electronics, and Tuning' started by accordin2vtec, May 21, 2007.
  1. accordin2vtec
    accordin2vtec /Blind|Side\
    Lufkin, TX
    ok, really noobish question here, but I gotta learn somehow (I searched), is this a complete parts list for tuning a chipped ECU or am I missing something?
    OBD2b to OBD1
    Conversion Harness
    Products for DIY ECU Enthusiasts who want to save money and do it right. TurboEdit, Uberdata and Crome supported here at Xenocron.com
    USB Datalogging Kit
    Moates BURN1 USB Chip Programmer
    Chipped OBD1 VTEC ECU
    ok, now for the questions, do I need the chip burner to write files and maps to the chip, or can I do that with the datalogging kit, as money is always an issue and any money saved is good. Thanks in advance.
  2. stuntstere
    stuntstere Member
    You need the burner to write the program to the chip. The datalogger just tells you what your engine is doing. You are also going to need a wideband o2 for proper tuning.
  3. accordin2vtec
    Lufkin, TX
    ok thanks bro, would that cut if for a turbo setup or would I need extra parts for the MAP sensor to not put me into limp mode?
  4. pissedoffsol
    skimp on the burn1 and just get an ostrich. its battery lasts like 30 years or some shit, so you can just leave it in the car if you want. you can always burn from it later. But tuning without a romulator is a huge pain in the ass (every time you make an adjustment, you need to re-burn a chip) and will cost a fortune in chips.
    the wideband o2 is a must ( i like the lm-1 Products for DIY ECU Enthusiasts who want to save money and do it right. TurboEdit, Uberdata and Crome supported here at Xenocron.com )
    and an EGT is a 'plus' especially if you are turbo.
  5. GSRCRXsi
    MD
    having the ostrich is good for tuning as you can make changes on the fly but burn a chip when youre done. ive heard many stories of the ostrich causing errors when left hooked up as a chip.
  6. nce
    nce New Member
    ostrich is the way to go much easier than burning chips and u could always use a chip burner when done tuning so u dont have to leave the ostrich in the car but ive had one on my car for about a year now with no problems
