PG7 ecu in 88 hb
Discussion in 'ECU's, Electronics, and Tuning' started by xxk0ssxx, Dec 28, 2002.
  1. xxk0ssxx
    xxk0ssxx Junior Member
    i am doin a mini me swap and i have everything pretty much done and wired (ecu harness,injectors,resistor,sensors) and i read that i could swap in a crx si or 88' 89' teg ecu, so i got the PG7 (88'89' teg) ecu and i was wonderin if anybody heard of this bad or good. i know its goin to be running a little rich. how should i tune it (cam gear, fuel pressure regulator,etc...) its a Z6 head in an 88 civic hb. any input would help thanx.
  2. djextremity
    djextremity Senior Member
    in your rearview mirror..wait..
    You should run a P28.
  3. Jeef
    Jeef NO MA'AM Moderator VIP
    Just wire it up for the p28 which is the ecu for the z6. I used the pg7 on my z6 swap and it ran like shit.
  4. xxk0ssxx
    i haven't been able to find anything on how to wire it for the p28 besides cutting all the connectors and re-wiring the p28 connectors and even then i can't find a p28 with the connectors, also i was goin by a website 4thgenerationcivic.com and i followed that and my wires are all hooked up to run a pg7. is there n e thing i can do to make it not run like shit besides the p28 if i can i would go with that. also is 11:1 bad on my motor, i know if i turbo it i can blow the shit outta it but how about for daily driven occasional racing? thanks
  5. pissedoffsol
  6. Jeef
    If you are planning on going trubo, then get a zdyne one wire conversion. Its like the Hondata but for non obd ecus. Also you can buy a harness from lelopez on www.honda-tech.com so you don't have to reiwre the ecu plugs.
