piecing together a kit for 00 si how much???
Discussion in 'Forced Induction' started by trevorsevoviii, Apr 16, 2008.
  1. trevorsevoviii
    trevorsevoviii New Member
    hey guys, i just bought a 00 civic si. it already has exhaust and basic bolt ons. car only has 68k on it. im wanting to piece together a turbo kit for it where i can safely and reliably get atleast 200whp. i know the stock bottom end can easily hold that. i dont want anymore that 230whp because i had way to many problem with my evo and to much power loses way to much reliablility. So what is a rough estimate of how much it will cost me to piece a kit together for my goal range and if i do it right will the car be a reliable daily driver. if not im not gonna do it because i cant afford to have the car breaking all the time like my evo. thanks guys.
  2. Luis998
    Luis998 Honda Enthusiast
    Orlando, Florida
  3. YBLEGAL
    YBLEGAL Regular Member w/ Cheese
    NW Indiana
    exhaust mani: $150~1000 depending on used or new and brand, style
    turbine: $100~800 depending on used or new. a T25 would be fine (used mitsubishi turbo) or a T3
    tuning labor, chip: $400~1000
    BOV: $50-300
    wastegate if applicable: $100~400
    charge piping: ~$200
    downpipe: ~$100
    injectors: $100~400
    misc oil/coolant line, clamps, etc: $50~250
    intercooler: $100~500
    ~GSR cams: ~$250
    about $1350~$5200 on my estimates :shrug:
    it can deffinatly be reliable for 200whp DD. :thumbsup:
  4. b16stalyun
    b16stalyun New Member
    NC
  5. garyeboy
    garyeboy New Member
    im doin exactly what your doing i have an 00 si i'm turbo'ing. im using s t3 super 60 greddy bov tial WG and i;ve peiced everything together for around 2300???
    hey does anyone know what size injector i should shoot for with 8 psi and that setup....i've never gotten a straight answer on that on here
  6. YBLEGAL
    NW Indiana
    the amount of fuel you need is dependant on the amount of air flow that will occur through the head with the cfm of turbo taken into account.
  7. b16stalyun
    NC
    want to find your injector size?
    try this (it gives you a rough estimate...):
    horsepower x B.S.F.C.
    # of injectors x .80
    that will give you lbs/hr
    then multiply that by like 10.5 to convert it to cc/min
    so like a b16a (stock):
    160hp x .5
    4 x .8
    this will give you 25
    25 x 10.5 = 262.5 i think honda uses 240cc for everything except prelude. f the smaller size they use is probably for fuel economy or lower emmissions.
    on average your B.S.F.C. on a n/a car would be around .5. turbo/supercharged will be around .6.
