StarBellieAngel
found this on another forum... if it's been seen before... well... too bad.
After every flight, pilots fill out a form called a gripe sheet, which
conveys to the mechanics problems encountered with the aircraft during the
flight that need repair or correction. The mechanics read and correct the
problem, and then respond in writing on the lower half of the form what
remedial actionwas taken, and the pilot reviews the gripe sheets before the
next flight.
Never let it be said that ground crews and engineers lack a sense of
humor. Here are some actual logged maintenance complaints and problems as
submitted by Qantas pilots and the solution recorded by maintenance
engineers. By the way, Qantas is the only major airline that has never
had an accident.
P = The problem logged by the pilot
S = The solution and action taken by the engineers
P: Left inside main tyre almost needs replacement.
S: Almost replaced left inside main tyre.
P: Something loose in cockpit.
S: Something tightened in cockpit.
P: Dead bugs on windshield.
S : Live bugs on back-order.
P: Autopilot in altitude-hold mode produces a 200 feet per minute
descent.
S: Cannot reproduce problem on ground.
P: Evidence of leak on right main landing gear.
S: Evidence removed.
P: DME volume unbelievably loud.
S: DME volume set to more believable level.
P: Friction locks cause throttle levers to stick.
S: That's what they're there for.
P: IFF inoperative.
S: IFF always inoperative in OFF mode.
P: Suspected crack in windshield.
S: Suspect you're right.
P: Number 3 engine missing.
S: Engine found on right wing after brief search.
P: Aircraft handles funny.
S: Aircraft warned to straighten up, fly right, and be serious.
P: Target radar hums.
S: Reprogrammed target radar with lyrics.
P: Mouse in cockpit.
S: Cat installed.
P: Noise coming from under instrument panel. Sounds like a midget
pounding on something with a hammer.
S: Took hammer away from midget.
next flight.
had an accident.
descent.
P: IFF inoperative.
S: Cat installed.
