Piston question
Discussion in 'Engine Building' started by 757DC4R, Sep 22, 2007.
  1. 757DC4R
    757DC4R New Member
    Hey guys. I'm new to the forum. I'm from Virginia Beach and I have a question for you guys. I have a 98 ITR engine that needs new piston rings and sine I will be replacing those, I'm going to buy new pistons as well. Now my question is: What kind of modifications will I need to do if I go for CTR pistons? Do I need to do something to the head? Get cams for that kind of compression? The engine is completely stock. I just want a bit more power. Or: should I go with oversized ITR pistons?
    Any help would be greatly appreciated.
    Thanks
  2. 757DC4R
    757DC4R New Member
    I never said I will be doing the work. I just want to know what are my options. Is there anything wrong with that?
  3. 757DC4R
    757DC4R New Member
    Here it goes: It is my daily driver and I just want to gain some HP. Nothing crazy. The engine is completely stock and right now I do not have any plans to do any head work.
  4. reikoshea
    Dallas, TX
    dump the egos guys.
    yes you can use those pistons in your stock itr, the problem is gonna be that you will be pushing 12:1 compression, and thats hard to do on pump gas.
  5. 757DC4R
    757DC4R New Member
    That's what I thought. What about oversized JDM ITR's? Or P30's?
  6. reikoshea
    Dallas, TX
    p30 and p73s are pretty close in CR....its doable.
  7. 757DC4R
    757DC4R New Member
    Do I need rods for the P30's?
  8. reikoshea
    Dallas, TX
    id be lying if i told you knew without looking it up.
  9. dtob
    dtob New Member
    12:1 isn't really that hard on pump gas but you will need a good tune and 94 octane.
  10. formby
    formby learning in progress
