Piston Ring Question
Discussion in 'Engine Building' started by EGDriver93, Jan 25, 2010.
  1. EGDriver93
    EGDriver93 New Member
    I've got about 180K miles on a D16Z6, was wondering how I know when to replace the piston rings? I'm getting more of a ticking sound, no knocks. Compression is good.
    I am already in the process of doing a full stage 3 Z6 head from Exospeed. Should I re-do the pistons, rods, bearings, rings as well?
    Any input is greatly appreciated.
  2. EGDriver93
    Anyone? Don't think this is too dumb a question.
  3. Bobby17772
    Bobby17772 New Member
    Enfield, CT
    I think what you're hearing is known as honda tick, everything is fine, you don't have to worry about the rings, as long as the compression is fine thats all that matters
  4. EGDriver93
    Thanks man. I have been searching around and that seems to be the consensus among Honda owners. So a drop in compression means rings are bad though right?
    If so, I'll just keep tabs on that. Thanks again.
  5. Matts96HB
    Matts96HB . Moderator VIP
    a drop in compression can have something to do with the valves as well
    i wouldnt worry about it unless the car is smoking and or making a LOT of chatter.
  6. EGDriver93
    Yeah it's not. Its more one of those, "what the hell is that ticking?," from an anal driver who hears every little sound. I'm sure people can relate. That's why I came on here to ask, haha.
  7. RoughKnight
    RoughKnight Christmas Car
    Ottawa, Ont
  8. josh_crewdson@y
    josh_crewdson@y New Member
    nova
    could be valve clearances or the lma's on the intake side. check your valve clearances. never the less iv'e noticed hondas have a lil tick at idle, both my y8's do it a lil when theyre warm.
