Please help!!!!!!!!!!!!!!!!!!!
Discussion in 'HYBRID -> EG-EK / DC' started by iphoneate12, Oct 15, 2012.
  1. iphoneate12
    iphoneate12 New Member
    I have a 95 civic coupe ex with a jdm b16a turbo. I'm running a vrigin p28 ecu and it has dsm 450s injectors. it fires up good on the first try then i let it sit there and driver it down the road and back by the time i get home and turn it of and fire back up just about 5 seconds after i turn it off, it will not start:( idk what it is, i already bought a new fuel pump walbro 255, and still it will not start after i turn it off:( battery is fully charge.:confused::confused::confused::confused::confused::confused::confused:
  2. eg6sir
    chip and tune your ecu to your swap
  3. Briansol
    You can't run larger than stock (240cc) injectors without a map that compensates for them on your ecu.
    pull those out and put the stock injectors back in before you wash out your cyl's.
