i got a f22b head and want to put it on an h22a block... the question i got is what Wire Harness do i need and what ecu? the setup is goin into an eg. thanx for the info and help.
Quoted post[/post]]
why on earth would you do that? if you were going to do anything it should be the f22 bottom end with the h22 head. the f22 head has oil holes in it that the h22 block will not have. so unless you can find away to make that work (good luck). just buy an h22 head for the h22 block...you wont regret it. you can find h22 heads pretty cheap.
