PR4 CONVERTED TO P28?help!!
Discussion in 'ECU's, Electronics, and Tuning' started by StealthMicro, Aug 26, 2006.
  1. StealthMicro
    StealthMicro New Member
    Marysville/everett WA
    HI,Iwas wondeing if its true that i can run my pr4 ecu,obd1-so it operates my d16z6 /vtec like a p28,can it be converted like that?any one got a link showing how?
  2. MikeBergy
    MikeBergy Blah blah blah....
    Central Coast, CALI
    You can't use an obd0 pr4 on an obd1 system; you'd have to convert your car to obd0, which would be dumb. I believe you can do a 1-wire vtec conversion on obd0 pr4 ecus, but it's prolly in your best interest to avoid the hassle, and spend a little extra cash on the p28. They aren't all that expensive. But go on to pgmfi.org if you want to learn more about ecus, there is a LOT more information than you'll ever need there.
  3. ChrisChhorn
    ChrisChhorn New Member
    92-93 integras have obd1 pr4's.......
  4. LateApex31
    LateApex31 New Member
  5. StealthMicro
    Yeah its the 1720, i may just covert it for the practice (i looked inside it and it has not been converted yet) ,im still getting a p28 too,thanks for the help!!
