Prodject H_EK-R
Discussion in 'HYBRID -> EG-EK / DC' started by DRI13, Jun 25, 2011.
  1. DRI13
    DRI13 New Member
    Ok so I've done some research to see what i could find, I am going to do an h-22 swap for my 99EKex. This IS my dd that i love but the D has got to go. I have plans of the CTR 5-lug conversion, NX widebody, and more than likely suspention upgrades.
    See my thing is I need everything (p/s a/c ect.) to still work as well. But for this I need a lil advise, So here is the plan.
    I can get-
    Euro-R h22 motor
    T2W4 transmission
    98 prelude wiring harness / civic harness
    OBD2b to OBD2a converter
    shifter
    PCD ecu
    HASport mounts
    HASport axles
    prelude intermediate shaft
    95 prelude transmission bracket
    (?) dual core radiator+ slim fan (5" total enuff?)
    Explicit alternator kit
    Or would the h2b work out better?
    Something like this-
    Euro-R h22 motor
    s80 GSR transmission (lsd)
    PCD ecu
    QSD h2b
    mounts
    custom header from ?
    I Think i needed a 98 A/C bracket which will use stock compressor and custom lines.
    For P/S I need 97 prelude bracket , 97 accord pump and line. (will the euro work?)
    And that is for both str8 h22 and h2b right?
    It being Euro-R do I still need custom fuel line and how do I get around the resistor box or is it just better?
  2. DRI13
    DRI13 New Member
    If I did forget something I need Please remind me.
  3. DRI13
    DRI13 New Member
    also the euro-r shifter and cables WILL work right?
  4. DRI13
    DRI13 New Member
    Anyone know where i can find 92+ p/s pump and/or bracket?
    Is the hcp a/c bracket a better choice than oem?
  5. RHDism
    RHDism Right Hand Drive guru
  6. FLounder
    FLounder power hungry VIP
    north palm beach, FL
    sounds like you have a pretty good idea of what you are getting into. if i was you, i would read every thread on every forum i could find about h22 and h2b setups, just to see how other people have done it, and what works best. you have someone to tune the car for you?
  7. DRI13
    DRI13 New Member
    Yea I've been reading and looking into what I need, and what I'm getting myself into. I believe I am going strait H, my big thing is I don't have a garage to do it in so this can't drag out to long, so I want to be prepared. And no I really don't have anyone to tune it for me, so that will be an experience.
  8. DRI13
    DRI13 New Member
    I was wondering how bad is the cable shifting
  9. monotech
    monotech Member
    H series is bad ass I had a 92 Eg H22 on 100 shot of nitrous it was sick.
    cable shifting is way different vs the standard steel linkage. I dyno tuned it and made a master program out of it and I also have some good h22 street tunes, let me know if you need one. It's best to go OBD-2B to OBD-1 jumper with P28 chipped, less sensors to deal with and more tuning options. H2B is the way to go aka K killer but I would go with ITR JDM tranny for 4.7 final drive.
  10. DRI13
    DRI13 New Member
    how long will an d-series tranny work?
  11. E_SolSi
    right up until it doesnt
  12. DRI13
    DRI13 New Member
    Ok fine how well
  13. h2bcivic
    h2bcivic New Member
    iam looking into the same swap you should do a right up when you start. i would love to see it i picked up a h22a4 and tranny yesterday just need a shell so i can start it iam going h2b thogh for sure i have a 2000 lude and the gears are way to long!
