Pulling code on AP1.
Discussion in 'General Tech and Maintenance' started by GlassHeadlights, Jul 7, 2010.
  1. GlassHeadlights
    Calgary, AB
    We already had the matenance light on but the check engine light came on today on our 2002 S2000. Any way to get codes without a reader on this one?
  2. eg'sforlife
    eg'sforlife New Member
    29 stumps, CA
    go to autozone have read it for free.
  3. GlassHeadlights
    Calgary, AB
    They're not up here. I read there's a little plug you jump, I'll look for it.
  4. E_SolSi
    pretty sure the plug jumping is just for OBD-1 cars
    OBD-2 you need to hook up to a scanner as far as i know
  5. GlassHeadlights
    Calgary, AB
  6. GlassHeadlights
    Calgary, AB
    I tightned the gas cap and reset the ECU and the light stayed off for 5 minutes.
    My guess is O2 but I'll get it scanned. Thanks guys. :)
  7. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    IIRC none of the newer model cars have the jumper connector you're looking for(in other words 01 Integra and 00 Civic were the last to have this).
  8. GlassHeadlights
    Calgary, AB
    Yep, couldn't find it. It still runs and drives great...weird.
  9. E_SolSi
    most parts store chains will check your codes for free... at least they do in the US im not sure about up in Canadia...
    if we are making bets on this... im gunna go with: its a code from your secondary O2 reporting catalyst below efficiency (ie: your cat is shot)... or possibly the O2 pre-heater is not working... but leaning more toward the cat
  10. phunky.buddha
    Dallas / Fort Worth, TX
    There is a way to jumper the ECU to show blocks of codes that are all related- it's on s2ki somewhere. I found it before- let me see if I can dig it up again.
  11. phunky.buddha
  12. GlassHeadlights
    Calgary, AB
    Wow! Awesome info! A guy at my dads work has a code reader so he might have already got it done, but if not I'm doing that!
  13. phunky.buddha
  14. GlassHeadlights
    Calgary, AB
    Borrowed a code reader from a friend.
    E called it haha.
    P0141 Secondary Heated Oxygen Sensor (Secondary HO2S) (Sensor 2) Heater Circuit Malfunction
  15. E_SolSi
  16. GlassHeadlights
    Calgary, AB
    Lol^
    Common problem I guess?
  17. E_SolSi
    no clue... no experience with S2000s
    purely a guess
    just when there is a code that doesnt really seem to effect anything those two are what come to mind
  18. GlassHeadlights
    Calgary, AB
    I see. On the code reader it said "Bank 1 Sensor 2" or something. :hmm:
  19. E_SolSi
    means the secondary O2 after the cat
  20. GlassHeadlights
    Calgary, AB
