psi is meaningless
stock fuel pump supports 220 whp. no need to upgrade under that power level.
stock injectors are 240cc.
200hp eclipse's come with 450's. that should tell you something right away. the stock honda injectors are nearly peaked out form the factory. plus when you boost, you run richer than in an all motor set up, thus requiring more fuel per power to keep it on the rich burn side.
He said larger injectors at 7 lbs with is not needed.
when you upgrade to bigger injectors, should you get your car tuned or can you just leave it how it is?
