radio code for honda accord 2003
Discussion in 'Accord' started by hamimad, Feb 2, 2012.
  1. hamimad
    hamimad New Member
    how do I unlock the Radio code for honda accord 2003 with serial no. M4G478020
  2. eg6sir
    look in your owners manual .. it should be in there somewhere.. if not, you gotta go to Honda
  3. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    if not there try on the side of the glove box.
  4. phyregod
    phyregod !!YTINASNI
    Central Texas
    Should be an anti theft radio card in the owner's book. If not, check every single page of the manual. Look for any random numbers in ink pen or a small black and white sticker. If not there, check under the under hood fuse cover. If those all strike out, head to your dealer. They can look it up by vin number. And don't let them tell you they can't. I know for a fact that they can. It requires a phone call usually.
  5. double0Si
    double0Si ლ(ಠ益ಠლ) VIP
    Columbus, Ohio
    :werd: Mofos tried to tell me I had to let them pull the radio out and take some numbers down too. AND it would be two hours worth of labor. Good thing I knew better.
  6. dc4dude
    dc4dude Member
    chicago, il
    call the dealer.. ask for the parts department... if the guy there is cool, he will give you the code... try a few dealers... ive done it a few times... good luck!!
  7. RichieB9280
    RichieB9280 New Member
    The dealer is given three stickers, one goes on the pre delivery inspection (PDI) repair order (RO), one is placed on the anti theft radio code card and the other can be hidden somewhere or simply thrown out. I used to put them on the glove box out of site so that it could be found when the glove box was removed.
    You can try holding down the 1 and 6 key on your radio, this may or may not flash the radio's serial number. The dealer can use the Honda radio's serial number on in.honda.com to get the radio code.
    Or if the dealer that sold the car is smart they should have it documented on the PDI RO.
  8. RichieB9280
    By "I used to put them" I meant tie extra sticker... :rolleyes:
  9. RichieB9280
    This works on some Honda radios, not all. I don't remember which ones. I quit fixing Honda's in 2006.
