red line problem
Discussion in 'Accord' started by accordex98, Nov 24, 2008.
  1. accordex98
    accordex98 New Member
    sup guys i have a question i have a 96 accord lx 5spd how come is it dat wen im 4th gear i can onli take my rpms to 6 grand an in 5th gear i can onli take to 4an half how can i stop da rev limiter anybody kno
  2. 95b16coupe
    95b16coupe New Member
    ct
    :emofo:
  3. accordex98
    all im sayin iz dat wen in racin i can onli take my 4th gear to 6 thousand an in 5th gear i can onli tak the car to 4 thousand
  4. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    english again,
  5. t3t4delsol
    t3t4delsol New Member
    York, Pa
    wow, idea, stop racing and get back to english class.
  6. BrutalB83
    Rochester Hills, MI
    Is your car even modified at all? If the engine isn't built to rev higher then the factory limit, then stop trying to do it, moron...
  7. George777
    George777 ^^ Likes Bewbies
    With your mom
    When you get your car up to the RPM that you want, just keep holding the gas down. It may take a minute or two, but you might get it to go higher than 4 or 5 thousand RPM's. Keep repeating this in ALL the gears to make sure that it allows you to get to the highest RPM possible.
    Let us know how that works.
  8. newb
    newb phresh VIP
    Backwoods Northwest
    First, make sure you have a perfectly clean, static free workplace. Then, take the ECU out from under the dash and take it to your workplace. Carefully mark the exact center of it with a felt pen. Now, find a heavy object (3 pound sledgehammer works great, but large rocks will do the job) and hit the ECU as hard as you can. Only do it once though. Now put it back in the car, and your rev limiter will be gone. :thumbsup:
    2 people like this.
  9. AHHVTEC
    Alabama
    rolf
  10. austin20110
    austin20110 New Member
    Northern Va
    dude dont listen to those losers lol all you got to do is when you get to that rev limitor push in the clutch and make sure your still giving it full throttle and then let off the clutch as fast as you can.... lemme know if this helps
  11. 95b16coupe
    ct
    here is your rev limiter. open the ecu, pop it out and you are golden.
  12. GlassHeadlights
    Calgary, AB
    Wtf? Is that a actual Hondata chip?
  13. Luis998
    Luis998 Honda Enthusiast
    Orlando, Florida
    lmmfao!!!!!! Hahahhahahhaahahaha rep!
  14. hatukazi
    hatukazi ambitious...but rubbish
    Big Lake, MN
    seriously dude, your car is speed limited to 115 MPH.
    I'm not exactly sure what that works out to for rpm in 4th and 5th gear but try looking at your speedometer when your revs cut out.
    Honda does this to keep jackasses from blowing up the cars they put so much work into.
    if you enjoy walking past your busted car everyday because you can't afford a new engine, just keep revving the piss out of it until it blows up, do us all a favor and make a video of it so we can all share in the amusement.
    and typing in english will make you seem not so much of a retard.
