resistor box removal?
Discussion in 'HYBRID -> ED-EF / DA' started by blasterman87, Jun 16, 2009.
  1. blasterman87
    blasterman87 New Member
    i know im soposed to remove the box to use obd1 injectors, but how? ive read to unplug and solder the wires together, but that seems odd, to just solder 5 wires together as 1, is this how its done or do i solder them together seperatly by color?? and also will obd1 injectors just plug into my 89 si harness??
  2. jlicrx
    jlicrx Senior Member
    Colorado Springs
    cut the 5 wires at the green connector that plugs into the resistor box - connect all four of the red/black wires (that go from the resistor box to each injector) to the yellow/black wire coming from the round 8-pin connector
    yes the OBD0 clips will plug into the OBD1 injectors
  3. HATCHET_HONDA
    HATCHET_HONDA scottie fizzle
    hobart, indiana
    wrong.....obd 1 injectors require obd1 clips. obd 0 will not fit them
  4. jlicrx
    Colorado Springs
    i have done at least a dozen OBD0 to OBD1 conversions and never changed the clips - just plug right in
  5. blasterman87
    ive read that it plugs in and that it doesnt, i guess ill find out
  6. HATCHET_HONDA
    hobart, indiana
    obd 0 clips wont fit obd1 injectors....been there , swapped that. done
  7. blasterman87
    maybe someone else has input on this
  8. HATCHET_HONDA
    hobart, indiana
    well i mean i just went into my garage...took obd 0 clips i cut off my 90 si when i did my swap and attempted to clip them on the obd 1 injectors on my d16y....dont fit
  9. jlicrx
    Colorado Springs
    D16Y7 and D16Y8 have OBD2 injectors which won't work with OBD0/OBD1 clips
  10. HATCHET_HONDA
    hobart, indiana
  11. D16SiHatch
    D16SiHatch New Member
    why would you splice into a wire on the other plug. all you need to do is take all 5 wires in that green plug and solder them together.
    and yes, jlicrx is correct, obd0 injector clips will work on obd1 injectors.. with some slight modification. you have to take an exacto blade and remove a notch or two from the inside of each clip so that it will slide onto the obd1 injector.
