rev limit redline
Discussion in 'Civic and del Sol - EG and EK' started by zap45, Dec 6, 2008.
  1. zap45
    zap45 New Member
    albuquerque nm
    ok so i installed a cluster with a tach in my swap dx.
    my question is i dont know the true rev limit or redline of my f22b dohc yet? anybody know? btw i have long gears ratio if this make any difference thanks
  2. D16SiHatch
    D16SiHatch New Member
    well when the revs stop climbing and you hear Bwop Wop Wop! then you'll know lol. in all seriousness though, i think its about 6500 rpm
  3. George777
    George777 ^^ Likes Bewbies
    With your mom
    A stock F22B stops creating power right around 6k. It'll be pointless to rev much past that.
  4. madracer
    madracer Boosting B16A2
    Redline
    Here is your answer:
    This engine was used in the 1992-1996 Honda Prelude Si in Japan. It is similar to the H23A,.
    Specifications
    • 2.2L
    • Bore × Stroke: 85.0 × 95.0 mm
    • Displacement: 2156 cc
    • Valve Configuration: DOHC, 16 valves
    • Compression ratio: 9.3:1
    • Max power: 166 hp (119 kW) @ 6000 rpm
    • Max torque: 150 ft·lbf (200 N m) @ 5000 rpm
    There you go, hope this answer your questions.......................................
    Good luck....................
  5. zap45
    zap45 New Member
    albuquerque nm
    u guy are awesome thanks alot
