rev limiter on a stock b16a2
Discussion in 'General Tech and Maintenance' started by Elayna, Jul 14, 2009.
  1. Elayna
    Elayna New Member
    New York
    whats the rev limit on a obd2 b16? my ecu is a obd2 p30 from a 96 del-sol. the ecu & engine are stock. dont wanna hammer it to find out.......... not yet anyway lol!:D
  2. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    I think its 8100rpm
    My OBD1 p30 JDM is 8100rpm
  3. Elayna
    Elayna New Member
    New York
    cool thanks im used to the old d-16 that was like 7200. i was lifting around there with the new motor and it seemed like the vtec just kicked in as i was lifting
  4. blasterman87
    blasterman87 New Member
    its 82k for the b16a1 and b16a2
  5. jamesA
    82,000? wow. thats a high revver.
    Stock b16a2/3 is 8000, but it won't kick off the engine until around 8100ish.
  6. blasterman87
    82 is when my jdm b16a1 kicks in
  7. Elayna
    Elayna New Member
    New York
    well it is much higher than i thought thanks every one the vetec seems to engage about 65ish or so does that sound right?
  8. blasterman87
    it should be 4-5 for vtec
  9. FLounder
    FLounder power hungry VIP
    north palm beach, FL
    im pretty sure stock vtec is at 5500 rpms on b16a
  10. jamesA
    Vtec engagement is 5500 rpm, max torque is 111 @ 7000 rpm and max hp is 160 @ 7600 rpm, redline is 8000 rpm. Stock B16a2/3. JDM models may differ slightly.
  11. buttered corn
    buttered corn New Member
    JDM redline is 8200. But you can always raise the bar a little, will need new internals.
  12. Elayna
    Elayna New Member
    New York
    you guys are good it is engaging at 5500 and it redlines at 8000 thank you for all your help this forum has been so much help.now that all is running properly time for some mods hmmmmmmmm whats first............
  13. buttered corn
    depends what you use it for.
    autocross - vortech intercooled supercharger kit comes at ~3200. Your block is good up to ~270hp.
    turbo is better for anything else other than autocross imho.
  14. jamesA
    Start small, don't jump right into power adders.
    I'm with E all the way. Safety mods first. Good rotors, good pads, brake lines and make sure it's tuned up properly. A nice suspension setup will help along the way. Learn the car best first when it's slow, then build it to suit your ultimate goal. Intake, header, exhaust, intake manifold, shifter, then power adders.
  15. Elayna
    Elayna New Member
    New York
    i have experience w/ nitrous on small block v8s whats your opinion? my motor is stock but completley rebuilt by a professional engine shop
  16. jamesA
    SB V8s with fat tires on the back and a 1595 cc FWD engine will respond very differently.
    If you go for nitrous its all in the tune. Don't throw it on and then go spraying it, TUNE it so it will handle it first.
  17. Elayna
    Elayna New Member
    New York
    i already upgraded brakes,suspenion it also has skunk2 exhaust and a aem cold air intake
  18. Elayna
    Elayna New Member
    New York
    im not looking for monster power this is a daily driver with some weekend dragstrip use bracket racing
  19. the sol man
    the sol man New Member
    Tennessee
    how about a new intake mani and bored throttlebody?
