Safe or not safe
Discussion in 'HYBRID -> EG-EK / DC' started by 95civicjdmgsr, Sep 1, 2006.
  1. 95civicjdmgsr
    95civicjdmgsr Pro Ticket Receiver
    Macon, MO
    :huh: Will I be safe running the B18C in my Civic without the a/c bracket/mount and the front tranny mount??? Sorry its a newbie "?"
  2. civicclutchh22
    civicclutchh22 CivicClutchH22
    new york
    You will be safe for now but if you shift fast then you will hear the engine shifting around.
  3. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    What? No, don't listen to this douchebag. If you have hasport mounts you'll be ok, but if you're using stock mounts you need all 5 mounts. Without the front lower mounts your motor will move around too much, and you risk breaking things such as sensors, axles, etc.
    Don't halfass your car, do it right the first time.
  4. daf
    daf Junior Member
    +1, youll be safe, but your engine wont. And even if you have hasport mounts, your still going to seriously put those MM though hell, and wont last as long as if you had all your mounts. Your car will also jerk funky too. My merc had 2 MM at when I got it, and it was gut renching driving it to Mech to fix (it was a 77 240D, im not rich).
  5. 95civicjdmgsr
    Macon, MO
    Does anyone have any idea where i can locate the front tranny mount and the a/c bracket/mount, our salvage yards around here are gay and none of them will sell them to me. Thats whats pissin me off with this. Thanks James
  6. daf
    daf Junior Member
    Are you talking about on your car? If so, they are basicly right across from each other. They are the front 2 MM on the lower part of your engine bay.
  7. girls_are_mean
    girls_are_mean New Member
    utah
    I bought just a b18c motor and trans, not a whole front clip and i found the 2 (the back trans mount, the right front trans mount) of the mounts i needed on ebay. if that helps. I've seen the ac bracket on there recently.
  8. 95civicjdmgsr
    Macon, MO
    i have located both brackets off a friend who just wrecked his car thanks for the info, James
