Seat Belt, Actuator Thing, Need Help Please!
Discussion in 'General Tech and Maintenance' started by 91si, Sep 14, 2007.
  1. 91si
    91si New Member
    Haha my car does that 2, i noticed i had a brand new battery then it was fine and car started good first day, the alternator charge the battery good 2.
    After 2 days i went to start it and it was dead.
    I found out it was the seatbelt lock actuator thing inside the right door.
    I know this cause when i unplug the harness the power from it, the actuator thing unlatches, and when i plug it in it latches, so its using power when its not supossed to.
    I unplugged it and my battery hasent gone dead since.
    So im wondering..Is the solenoid supossed to latch up all the time? Because it does and its killing my batt. Now i dont want to get in a wreck and have the passenger hurt because its not plug in, so im wondering if its just defective since this car has been in an accident.
    Can somone please check it out for me?
    Also what triggers the soleniods to lock the belts when you get into an accendent, so i can check that and see if thats the problem, and not the door actuator.
    This is on a 91 civic si hatch.
    Thanks.
    Oh yea and when it is plugged in, the dorr light stays on, even if all doors are closed.
    This is all with the key off and out the ignition. besides the door light.
    All i need is somone to take the door pannel off and check it out for me.
  2. 1988hondacrxsiR1
    1988hondacrxsiR1 Banned
    Midwest
    To remove panel. Use a special pry to remove the windows roller thing. All you have left is 6 screws around the panel side. Now pull from bottom to your way up. shouldn't be hard.
  3. 91si
    91si New Member
    Hm.. Let me re-phrase that.
    All i need is somone to go out to there EF take there door panel off and unplug the actuator power the to wires on top, and plug it back in, and see if it triggers the arm to move, or if it doesent do anything at all.
  4. 91si
    91si New Member
    Noone is down to help?
  5. CRX-YEM
    Wallingford, CT
    not swap related...... moving
  6. 91si
    91si New Member
  7. fixngo
    fixngo New Member
    Change it.. .just to be safe... might have locked up from the accident and got ruined like a week old milk shake
  8. Z6CRX
    Z6CRX übber ɐɾuıu etarip
    Pittsburgh, PA
    I think what he's trying to say is. He wants someone that frequents he forums to check it out for him. As in someone from the forum literally go out there and check it out. Am I right?:ph34r:
