simple rebuild?
Discussion in 'Engine Building' started by mptED3, Jan 16, 2011.
  1. mptED3
    mptED3 New Member
    Hi im new here and I am going to rebuild a spare d16 block i picked up and try to use my d15 head on this spare to replace the current i have now. i will try to keep updates as i go. I want to do this right the first time so any critiques of my methods is appreciated!
    here is what i have so far.
  2. Matts96HB
    Matts96HB . Moderator VIP
    just a word of advice: use OEM Honda seals/gaskets/bearings where possible.. nothing beats OEM
  3. lostsoulzprophet
    lostsoulzprophet delslow
    georgia
    i second that.:D
  4. mptED3
    mptED3 New Member
    thanks for the advice! i hope to have the d16 block ready to go in by summer and then once i rebuild the d15 block put that back in by the end of summer.
  5. mptED3
    mptED3 New Member
    slowly getting everything together... had to change alternator on the POS. what fun
  6. mptED3
    mptED3 New Member
    new plans. y8 head, intake, tb, dizzy, vtec solenoid. obd1 and mpfi. wish me luck!!
  7. MauricesCivic
    MauricesCivic New Member
    I like to polish the interior of the block, radius the nonmating sharp interior edges just enough to make the interior look nice, it's nearly free and makes me feel like I've put that little extra into an engine.
    For the most part there isn't much work, but every so often there are casting flaws that just bug the tar out of me.
    Its my opinion that your not going to get much if anything out of doing this other than slightly faster oil return to the pan and some extra bit of pride in going the extra mile.
    I got the idea your not crunched for time, it's just a thought.
    Maurice
  8. mptED3
    mptED3 New Member
    my time constraint just got more constrained. i need to have this new motor in my car by the middle of april. im sending the block to be tested and the head to be tested this week and i need to buy the conversion harness from hamotorsports; ECU Jumper Harness - OBD0 DPFI to OBD1. anybody have experience with this company?
    oh yeah how do i test to make sure a p28 ecu im buying is legit?
  9. mptED3
    mptED3 New Member
    doing the swap next week. putting in bearings this week, swapping all block components this week. here we go!
  10. mptED3
    mptED3 New Member
    what a disaster!
  11. Ichigo1174
    Ichigo1174 Member
    Florence, SC
  12. Dagnasty EF
    Dagnasty EF New Member
    Kenosha, WI
    how did a d swap become a disaster. I on edge to hear the fiasco
  13. mptED3
    mptED3 New Member
    i couldnt swap the coolant inlet line from the b2 to the a6. so i bought a jdm d15b non vtec and just slapped it in real quick. well not quick it took 2 months from start to finish with the change in plan! haha live and learn. no im waiting for more money to buy an obd1 dizzy and obd1 injector clips to finalize my vtec swap.
    but now ive got a d16a6 block with internals and new rings and bearings for sale!
  14. mptED3
    mptED3 New Member
    still at it. in fact i just did axles this past weekend. here are the pics.
    loosen lugs and spindle nut.
    loosen crown and damper bolt/nut.
    once ball joint is loose and axle removed from hub this is how it looks.
    everything reinstalled, minus spindle nut and crown nut.
    this image shows how i had to seperate ball joint. place and raise jack on lower control arm. place wrench between lower control arm and hub. release pressure from jack. if wrench, or piece of all thread in my case, is not ground at this point, step on assembly. it should seperate the ball joint. ( disclaimer: i in no way endorse this method as OSHA safe.)
    just another view of the last image.
    oh yeah, replace cotter pin on lower ball joint, torque everything down, buy tranny fluid and replace axle seals
  15. mptED3
    mptED3 New Member
    broke and lazy.. no vtec yet. but she is lowered!! and i polished my rims
