Skunk 2 Stage 2 head compression needs
ctrcivic
Looking to do a Skunk 2 stage 2 head build. Skunk 2 stage 2 cames, valve springs retainers etc. Basicaly I have been reading about needing a min amount of compression to make it worth going with the stage 2 cam. What is the ideal min compression number that I need to shoot for to benefit from the stage 2? I ask this because I am planning on running my usual 50-70 shot of juice on the motor. I'm just interested in building a reliable good performing allmotor build and just having the juice on tap if I need for that extra punch.
youll be fine in the 10.5:1-12.1:1 range. but 11.5:1 is the one i would go with...m2c
Thanks that is about what I was thinking. I'm sure if I run close to 11:1 then I will have better performance NA with the stage 2 over the stage 1 but when I am on the bottle the stage 2's will perform much better over the stage 1. Thanks for the suggestion
