Snowblowers vs wet snow
Discussion in 'Members' Lounge' started by reckedracing, Jan 16, 2013.
  1. reckedracing
    reckedracing TTIWWOP VIP
    NY
    does anyone know of any spray that would be good to use to prevent heavy wet snow from clogging the chute on a snowblower?
    maybe ski wax like we used to use on the metal shovels?
  2. chestercheeto48
    chestercheeto48 Senior Member VIP
    madison, WI
    i've never really had an issue with that here in Wisconsin. I am assuming you have the belts tightened and you are slowing down - correct?
  3. reckedracing
    NY
    the belt is actually a little too small so it never disengages, just put the new belt on this morning
    that was my first idea
    and i'm only running it in 1st gear, so thats as slow as it goes.
    the last few storms we've had here in NY have been snow followed by mist and rain, so its making a heavy wet mess
    I guess my next move would be to clean the carb because its having to run at half or 3/4 choke, so maybe its just not having the power to throw the slop out of the chute
  4. Briansol
    Use Pam cooking spray on the auger area and chute.
    like butta!
  5. INJEN78
    INJEN78 HS LEGEND
    OHIO
    like B said.any type of cooking greese.but it wont hold up for long..when i did snow removal the only remedy was a heavy duty blower.
  6. chestercheeto48
    madison, WI
    You could also try silicone spray.....
  7. D16Civic
    D16Civic Matt
    Chesterfield Twp, MI
    Is this a single stage or 2-stage blower? If it's a single there's probably not much you can do.
    I just let my neighbor do mine, although I've been thinking about a blower attachment for my lawn tractor.
  8. reckedracing
    NY
    this is a 2 stage snow throw
    toro 8hp 22 or 24"
    its a pretty decent sized snowblower, its just the real wet nasty shit once it gets above freezing and starts raining and getting real wet.
  9. phunky.buddha
    Dallas / Fort Worth, TX
  10. dc4dude
    dc4dude Member
    chicago, il
    Chiming in from chicago... Whats this snow you speak of???
  11. klyph
    klyph Dismember VIP
    North Pole, AK
    Any spray will last all of 30 seconds. Ski wax everywhere it's sticking and get the engine running 100%.
  12. tab
    tab Super Moderator
    Aberdeen, Washington State
    Definitely get the engine 100%. Drain the carb bowl, then check for fuel flow to the bowl. Fresh gas going through will help. Dirty fuel or a motor that has sat for a long time, those are good reasons to clean the carb. Small engine carbs are so simple, problems are easy to figure out/fix. If the float is ok, the main jets needs to be clean, and you're set.
  13. awptickes
    MD
    Don't use silicone spray. Don't use cooking spray.
    Use Ski wax, skateboarding wax, hard paraffin, or turtle wax on the entire interior of the blower, including the blades, chute, and any surfaces that receive the snow spray.
    Tab has some good suggestions too, make sure the engine is running right. I'd personally take it out on a warm day and run it just to blow away all that carbon and crud in the carb. Get it good and hot. and make the belts are correct, then let it cool down, and check the belts again.
    I thought most snow blowers were chain drive... I guess not.
  14. DarkHand
    DarkHand Senior Member VIP
    Chicago, IL
    Hey this reminds me... Whatever happened to the possible group buy of that coating that eliminates sticking? Like a permanent Rain-X. Coat your house siding and mud washed right off, etc. Remember that thread?
  15. awptickes
    MD
    Yeah. Someone said that their shop was going to put in an order.
  16. awptickes
    MD
