Can't/will not drive a wagon or hatch. Just have no appeal whatsoever for me.
nope...just one Z is leaving right now ...the yellow one. But I have a guy that sounds like he runs a restoration shop coming to look at parts, and I might be able to snag something from him for the other two.... lets just say...what I get will toss everyone here and on the other forums for a spin...Something soo unlike me...
/thread jack.
I still say Outback
Good buy, you should be happy, provided the car was taken care of. I work on Audis day to day, and the 02-05.5's are near the top of the list reliability wise.
Make sure you know the cars history, and plan on purchasing an extended warranty (Honda Easycare, Fidelity, Audi Assure). Since it's a 2005.5 (1.8T, not 2.0), be weary of the T-belt on that car, and get it serviced RELIGIOUSLY. Once you start skimping on services, things tend to snowball, and before you know it you are out $4k on one repair order.
One good thing is - the B6 A4 1.8T's are far superior to the 06+ A4's with the 2.0s.
Build quality is great, and the 6-spd is great for highway cruising. 6th gear around 75mph can still net you at least 28mpg.
We don't usually see any in for anything crazy, and if you can drive stick halfway decent - clutches can last 140k+ miles. Brakes can be a bit pricey, but if you do it yourself it's not bad. Keep an eye on the axle seals going into the trans, and the rearend. Some interior pieces have been known to peel and the paint chips away (ESP button, light switch, climate control). Coils tend to go on the 1.8T's and when one coil goes, I suggest replacing all 4 with the new style coils (red top, instead of black).
And for the life of the turbo on the 1.8T, try to change the oil every 5k. Recommended interval is 10k - which almost everyone goes by - but sludge will eventually start to accumulate and fuck up your oil drain lines and breather system.
woohoo! no wood interior! you have no idea how hard that is to find. lol
HATE wood interior trim. yuk.
let's hope shes good to ya. audi's tend to be 50/50.
one, you're in the shop once a month
the other, you've never been to the shop
lol
Ahhh. theB7 A4.
Well, theres good and theres bad. The good is, that the 2.0L is better on fuel than the 1.8T, and that it has a little more balls. The brakes are much better, and overall the interior is nicer (better buttons, steering wheel controls).
On the other hand, there are a few recals concerning the TFSI 2.0L. The first of which concerns the manifold pressure valve (kind of an active PCV valve). If this fails, you will go through a quart of oil every 1500 miles or so, and you will get the "Oil Min" light on. Theres a TSB out for it, so it will be replaced free of charge if it breaks. Additionally, there is also a hi-pressure switch for the direct injection that will occasionally go bad, but there is also a TSB out there for that as well. The 2.0's also will eat a little oil if you go 10k between oil changes, and drive it hard. Just the nature of the beast. You may need to add 1 qt for every 10k.
Well, good luck - and post some pics when you can.
how bout a 350z? If I had the $$$$ I'd do it.
I used to hate wood interior, now the wood trim in my friend's 328i grew on me. I hate light wood interior, but a black leather interior with deep cherry wood accents looks nice.
Hopefully everything I've read about the 2.0T B7 A4 being light years ahead of the 1.8T B6 is true even though its contradictory to what you just wrote.
