so i want a small turbo on my lsv
Discussion in 'Forced Induction' started by formby, Jul 27, 2007.
  1. formby
    formby learning in progress
    i want more power from my stock [81.5mm] block lsv somewhere in the 200-250whp range; and i want to spend under 500 bucks.
    i'm done with drag but ill be going to autox events in the near future.
    so i was thinking that if i got a small turbo and a simple set up i could have no lag and just enough turbo to get me to the 7.3k red line i use.
    when i mentioned my plan to Anthony he told me he had a turbo from a 90ish 300zx i can have free.
    [Garrett TB22/TB02 with integral wastegate, 9.8 psi max boost]
    the turbo is a t25 i think and i dont know much more about the turbo.
    1. i want to keep my AC, but i dont know who could make me a manifold with a flange to fit the turbo.
    2. i think the WG on the turbo will hit the block.
    3. i'm pretty sure this turbo will run out of steam at a low rpm. but i have no idea where
    i have an extra block and eagle rods that i want to build with stock sleeves and 10:1 cr for a future FI build. i also have 450 dsm tuner toyz injectors, and the the box to run them. ohh and the p28.
    what should i do?
    would the turbo make power?
    what happens when a turbo is maxed out at low rpms?
  2. formby
    ttt
    any comments are welcome
  3. Ryma
    Ryma Member
    I dont see it being an issue with that turbo. But I would use an ihi in the case of just that extra kick in the pants. they are pritty good at low end grunt, and are capable of reaching a high rpm. Its just that the tbirds are heavy as hell this turbo wasent a smart move for ford.
    But to me I say if your gonna end up building a motor fur FI later down the road I would put that 500$ twards that.
  4. formby
    i thought ihi turbos were smaller that the t25 from the 300zx. remember i have a 1.8 so i want a turbo the has just enough to give me 200whp an will reach its limits at around 7-8k
    i was researching on HT and it seems like the 300z before the 90s had a single turbo that was a t3.
    i wish i knew what turbo this was....ill take pics when i go over there
  5. Ryma
    Ryma Member
    Humm if its off a single turbo 300Z then it might be worth it. I dont know.
    Never seen a s ingle turbo Z
    I found this, google gave me 3 results and this one is the only one that had info on it.
    Turbo Introduction
  6. civicious
    civicious FüK-VTEC VIP
    Houston, TX
  7. formby
    nice! but expensive... i have to look into that turbo.
  8. pissedoffsol
    i wouldn't run a t25 on anything bigger than a zc.
    on an lsvtec, its going to be a turd, and you're just going to end up wanting to upgrade.
    and, wtf... baby > car parts
  9. formby
    i know.....
    i want to get it out of the way before he is born because once he is here i wont be able to get shit for a while. i also want a simple kit nothing major.
    thinking it over i think ill just save up all the cash i can and then ill see what i do.
  10. Matts96HB
    Matts96HB . Moderator VIP
    Disco Potato FTW.
    GT28RS
    Holy $300! But worth it.
  11. formby
    turbo's on hold.... i'm getting billed out the ass for the pregnancy
  12. Turbo&Auto
    Turbo&Auto Nick Go FAST!!
    East Burg, PA!
    that small turbo is going to make autox'ing prolly worse. It will come on real strong down low and make a fair amount of tq. It will just be ripping tires coming out of turns. OH, and it will blow crazy amounts of heat about 6-6500rpm....
