Someone Help! D16z6
Discussion in 'Civic and del Sol - EG and EK' started by delsolcharlie, Mar 19, 2007.
  1. delsolcharlie
    delsolcharlie New Member
    Augusta< GA
    ok i have a 93 civic del sol...with supposdely a D16Z6..is what the vin number tells me..my valve cover does not say VTEC..asi found out the D16Z6 was a VTEC..i have no solenoid..WHAT IS IT!!!
  2. danielthemanual1
    danielthemanual1 New Member
    GA
    a z6 with no selenoid.lol
  3. delsolcharlie
    Augusta< GA
    hell if i know...the vin says it is a D16Z6...but i know its not..and i know it aint a D15..so what is it?? haha
  4. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    if the motor says d16z6 but it dont have a solenoid its missing or its a non vtec head
  5. delsolcharlie
    Augusta< GA
    where exactly on the block would it say..im going off the VIN number...??
  6. AHHVTEC
    Alabama
    it will be on the front right were the motor and tranny come together, about a inch flat spot that will say d16z6 or d15b7 i think
  7. delsolcharlie
    Augusta< GA
    im going to take a look at it..its only 1 30 in the morning ha
  8. delsolcharlie
    Augusta< GA
    Yep!
    its the D16Z6 ....non vtec :(
  9. AHHVTEC
    Alabama
    no if it says d16z6 its vtec
  10. delsolcharlie
    Augusta< GA
    i dont have a valve cover that says vtec or a soleniod....here is what it looks like
    not my car but i dont have a pic of my engine and this is what it looks like
    where is the soileniod ??
  11. AHHVTEC
    Alabama
    it willl be right beside the pvc valve on the valve cove it will have a green plug on it
  12. delsolcharlie
    Augusta< GA
    alright ill check later..do you know what manual transmissions will bolt directly to this engine??
  13. AHHVTEC
    Alabama
    any 88 or newer d series but stick to 92+ because those are hydo like yours
  14. dtob
    dtob New Member
    here's where the solenoid should be if there is one. I made an arrow pointing at the one in the picture.
  15. Baker502
    Baker502 New Member
    just becouse it dosnt say vtech dosnt mean its not i have a buddy with the 93 si too. and his valve cover dosnt say vtech and it is.
  16. dtob
    dtob New Member
    Hahahahaha!!!
    I'm sorry but it makes me laugh every time I see it spelled that way.
    Ya my Si doesn't say Vtach on it either. Like mentioned above just look for the vtach solenoid with the green plug on it.
    Hehehehe
  17. delsolcharlie
    Augusta< GA
    i greatly apprciate it guys! thanks
    charlie
  18. demon87
    demon87 New Member
    I have the same motor. Mine has the vtec. My plug itsnt green tho. I did a swap and snagged a plug that had the same connections. I have a stage 1 cam from comp cams in and when it engauges at 4800rpm you can hear it. It sounds so alsome! ^_^ lol
  19. AHHVTEC
    Alabama
    hearing it is a bad thing and this thread is super old
