speedometer
Discussion in 'HYBRID -> EG-EK / DC' started by whiteciv88, Aug 18, 2008.
  1. whiteciv88
    whiteciv88 New Member
    ok after doing my first swap i had idleing problems. i found out that it was a vacuum leak it was the new throttle body gasket that i bought from honda. i made a new one and it runs fine now. my next question is what my speedometer doesnt work. i have it plugged in and the fuses are not blown could anybody help me out? please get back to me
  2. George777
    George777 ^^ Likes Bewbies
    With your mom
    Any CEL? Is it nonfunctional or does it just jump around? Give us a direction to head by telling us what it is doing. Check your VSS and make sure it is seated correctly/installed properly.
  3. t3t4delsol
    t3t4delsol New Member
    York, Pa
    the speed sensor in the tranny
  4. newb
    newb phresh VIP
    Backwoods Northwest
    Even tho the OP hasnt answered the question about the CEL, if his VSS was malfunctioning would that cause a CEL, or could it not be working and not causing a CEL?
  5. George777
    With your mom
    Based on my experience, as soon as the VSS/speedometer doesn't work, it trips the CEL...
    Unless there is a way that he bypassed all of this, i.e. an ECU or whatever...
  6. newb
    newb phresh VIP
    Backwoods Northwest
    Gotcha, makes sence. Thanks.
  7. whiteciv88
    sorry i havnt been on in a few hours. it doesnt work at all and i checked every thing that involves the speed sensor. like the fuses and the plug so what would be my next step? could i use my civic speed sensor or would it have to be from a b series trans
  8. BoostedHatch
    BoostedHatch get tha fuck out!
    Bossier City, Louisiana
    it will have to be from a b series trans and the little gear on the inside of the trans some times goes out so get another speed sensor and install it and it should work.
  9. awptickes
    MD
    This has been covered before.
    Does the battery light come on when you turn the key to RUN? Is the ALTC fuse intact? Any CELs?
  10. whiteciv88
    no i have cels but nothing for vss
  11. awptickes
    MD
    Which CELs do you have? The VSS will not show a CEL on its own, but other CELs will show which systems are damaged.
    You didn't answer all my questions.
  12. whiteciv88
    the codes that i am throwing are crank fluckuation (sp) ignition and vtec cause i have a civic ecu for now so any thoughts
  13. whiteciv88
    is it possible that the speed sensor is not working because i have a vtec ecu
  14. whiteciv88
    ok
  15. whiteciv88
    so here is the current position that i am with my car. I swapped it two weeks ago and i wired up the dissy. I had one wire left and it was the blue one. If i remember correctly that blue wire is for the tachometer but my tach works? The only thing that doesnt work is the speedometer and the odometer. So i checked the plug and its plugged up and the fuse isnt blown. so my question is what is the blue wire for on the distributor and why doesnt my speedometer work? my car is a 2000 civic ex with a b18b in it with a type r trans in it. So get back to me with any tips i will greatly epriciate it
  16. whiteciv88
    ok so i got the jumper harness for my car yesterday. i am running a ls ecu so i still have the problem of a speedometer not working. so any thoughts on how to go about fixing it do you guys think its just broke?
  17. awptickes
    MD
    Did you bench-test the VSS?
  18. whiteciv88
    cfk was still there
  19. whiteciv88
    yeah man i am hyped for that bypass the only code i am throwing is for code number 7 which is throttle position sensor could you please give me your thoughts on getting rid of that one
  20. whiteciv88
    ok where do you guys put the ecu cause it doesnt fit in the origonal spot that the civic was
