Hello guys, ever since I changed my brakes to big discs, everytime I stop my car and pull the handbrake it makes a squeaky noise. Especially when you shake the car or try to push it around. Is there a way to fix this?
The small filter is coming out of the valve cover. On a stock filter assembly the tube dumps back into you intake. On an aftermarket on you can just put a breather (small air filter ) on the valve cover. I'll assume that you friend has on aftermarket air filter!
